UDP Read does not receive data
Yes, you are listening on 1121 and 1122. If the device is sending to port 1124, it will not be seen.
Message 11 of 13
(2,517 Views)
My problem was in the IP header checksum.
The NIC card is set for 'IPv4 Checksum Offload - Rx & Tx enabled'.  The UDP packets that I was receiving from the PC (LabVIEW) had 0000 for the checksum.  Wireshark indicated that the IP checksum was 'disabled'. Header checksum: 0x0000 [validation disabled]
Of course I assumed this was OK for sending packets back to the PC. And Wireshark reported the same information [validation disabled].
When I added the correct checksum to my IP header for packets sent from the DSC, LabVIEW received the packet!
NOTE: I am successfully using 0000 for the UDP checksum, but to do that I have to disable the NIC card's 'UDP Checksum Offload (IPv4).
Message 12 of 13
(2,489 Views)
Thank you for the feedback!
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 13 of 13
(2,448 Views)
