UDP data transfer between RT desktop and host computer
i solved the problem by opening the port manually by following this guide.
https://www.tomshardware.com/news/how-to-open-firewall-ports-in-windows-10,36451.html
Thanks a lot for your helps guys !
cheers
Message 11 of 13
(1,227 Views)
Thank you for reporting back and sharing the solution!
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 12 of 13
(1,218 Views)
Most firewalls are a lot more fussy about inbound connections than outbound ones.
When I need a TCP connection between a windows PC and another external device/computer, I have the windows side instigate the connection.
I know this can't always be done, but when it can, it will save having to edit the firewall settings.
0xDEAD
Message 13 of 13
(1,211 Views)
