UDP on PXI causing errors
Hello all,
I have been using a UDP communication architecture between a Host PC (windows XP) and my PXI RT target (Labview 7.1).  It has been working fine up to now.  The packet size that I am sending has grown somewhat, from about 2kB to 5kB.  When I did this the UDP Write block running on the PXI target would return error 66, "Network connection reset by peer", and no data goes across.  I investigated this further and found that this will happen if the UDP packet size is larger that 4096 bytes.  However, when run on a windows machine, no error is occurs.
This error message seems rather odd, since I don't believe it is possible for a peer to close a UDP connection.  Also, if I do not feedback the error signal, subsequent UDP write blocks perform fine (packets smaller than 4096 bytes).  Anyone ever run into this before?
Jesse Hopkins
(2,983 Views)
UDP can be limited in size, it is not the same in all stacks !
We also bumped in the 4096 boundary once
greetings from the Netherlands
(2,980 Views)
I have fixed this problem by installing LabVIEW RT 7.1.1, and changing the C:\ni-rt.ini file to add the key "SendBufferSize = 65535" as described here: http://sine.ni.com/apps/utf8/niepd_web_display.display_epd4?p_guid=EF2BC05789697405E0340003BA7CCD71
Jesse
(2,971 Views)
