error 200077 with 6024E
not sure why i am receiving an error when running in labview, error states:
Error-200077 occurred at Property Node DAQmx Channel (arg 3) in DAQmx Create Channel (CO-Pulse Generation-Frequency).vi
Possible reasons:
Requested value is not supported value for this property
any suggestions?
(2,744 Views)
How many pulse trains are you trying to generate and are they continuous or finite? The first think that I would like you to do is to use a DAQmx Example for generating the pulse train. The examples are located in LabVIEW Example Finder under Help >> Find Examples >> Hardware Input and Output >> DAQmx >> Generating Digital Pulses.
For finite pulse trains, use Gen Dig Pulse Train - Finite.VI
For continuous pulse trains, use Gen Dig Pulse Train - Continuous.VI. Please let me know if the examples run without errors.
Hal L.
(2,731 Views)
