UDP open error in Lte framework 2.0.1
I am using USRP 2942R with Lte framework 2.0.1 with MIMO extension 2.0.1 but it always shows there is an error when I run the simulation without modifying the default configured values in the framework and hence the simulation doesn't work at all as attached in picture 1.
As a result, I run the simulation in the debugging mode and it shows that there is a block "UDP open" included within "Lte DL Host Initialization MIMO" VI which generates an error and hence the simulation doesn't run as shown in picture 2.
Can you please suggest a solution to solve this error?
(2,497 Views)
The issue is solved as it turned out it is related to LabView Communications program setup.
(2,423 Views)
