ULTRA SONIC HOW MUCH ERROR
HI
i try to use ultra sonic sensor to measure distance
what  and when the worst caser maximum error that may be happen???? and on which depend >>???
any information !!!!
best regards
hi ?Q>
Message 1 of 11
(3,740 Views)
Hi mangood,
1) read the manual of the sensor.
2) Read the manual of your DAQ device.
3) Combine the given error ratios by error propagation rules.
When you don't know how to apply point 3 you should read some basic books on "Measurement theory" - or consult Wikipedia...
Message 2 of 11
(3,708 Views)
The worst case error will occur when you operate the ultrasonic sensor in vacuum, because you will not receive any signal at all.
Lynn
Message 3 of 11
(3,694 Views)
@GerdW wrote:
Hi mangood,
thank you,i know these ponits
but you know some time practicatl result diffrent in some how from data sheat
so maybe some one work on it and see some error and i need how much  happen
best regards
hi ?Q>
Message 4 of 11
(3,689 Views)
Lynn
dear
i mean if the sensor say that 14 cm is the distance  but the acutal diatance is 16 so the error is 2 cm
this is what i mean for the error
hi ?Q>
Message 5 of 11
(3,687 Views)
Hi mangood,
what should we look at? You neither tell the type/producer of the sensor nor do you tell the type/producer of your DAQ device. We don't know anything about your measurement setup!
So points 1 to 3 of my first answer still hold true: look at the manuals of your hardware...
Message 6 of 11
(3,684 Views)
@GerdW wrote:
Hi mangood,
Devantech SRF04 / SRF05 Ultrasonic Range Finder
one of them i will use
hi ?Q>
Message 7 of 11
(3,675 Views)
mangood,
In addition to the information GerdW pointed out that only you have, you may also need to know the temperature, humidity, and atmospheric pressure along the path between the sensor and the target.
Lynn
Message 8 of 11
(3,673 Views)
@johnsold wrote:
mangood,
Lynn
dear
I will try it in my room so these measurement is hard to measure
did any one have approximation value ???
I mean from his experience
regards
hi ?Q>
Message 9 of 11
(3,665 Views)
Accepted by mangood
mangood,
You can use standard values from handbooks.  Any errors in your room will be much smaller than the one part in eight you mentioned in one of your earlier posts.
Ultrasonic distance measurements are based on the time it takes the sound to travel between two points so anything which affects the speed of sound in the air can change the result.  According to a table on Wikipedia the speed of sound increases about 1% for a temperature change from 20 to 25 degrees C.
Lynn
Message 10 of 11
(3,655 Views)
