ULx in LabVIEW - Error 10023 occurred at ULx Create Channel (AI-Temperature).vi:2950001
I need help figuring out what is wrong with my program.
There is no drop-down list for the temperature channels but they exist for the voltage channels. Even when I click browse an empty diag.box opens (image).
I have followed the procedure in this file but there is still no list.
When I try typing the path, it brings up the error.
Thanks for your suggestion
(5,003 Views)
Can you see the temperature channels in InstaCal? I seem to remember having to configure the board with that program before all the channels would work.
(4,984 Views)
Yes, I can all see the temperature readings when I call the analog test in InstaCal.
 I have also configured all the channels from InstaCal.
(4,974 Views)
What version of ULx are you using, and is it the newest one?
(4,886 Views)
Thanks for your responses.
Am not sure of the version, but I downloaded it within the last 6 months and my VI manager regularly update the LabVIEW packages.
Any idea on how to get the newest version just in case mine isn't?
(4,876 Views)
You have to get ULx from Measurement Computing as part of the MCC DAQ CD, from here: https://www.mccdaq.com/Software-Downloads
It looks like the current version of ULx is 2.22, part of MCC DAQ CD 6.60, released last September. You might try updating it and see if it makes any difference.
(4,858 Views)
