URGENT!! pls help me
Hei sorry for the third post as i am really desperate to finish my project before the deadline.
My project main task is to use labview to control a humanoid robot. So therefore, i got to make the motors in the robot run. I have the labview programme for making the motor run completed. Now, i need to add in the sensor to my motor control programme. This is the datasheet of my sensor http://sharp-world.com/products/device/lineup/data/pdf/datasheet/gp1s53v_e.pdf
My sensor is connect to J5 of the EPOS 2 50/5. I am using the sensor to limit the movement of the robot. Can u either teach or help me do the adding in of the sensor in labview? I have tried many ways to let labview read the sensor but still no avail..
(2,999 Views)
Shouldn't you be asking Maxon how to coonect that sensor to their hardware? I don't understand the connection to LabVIEW.
(2,986 Views)
i have already connected the sensor into epos2 50/5 , and my sensor can be read by epos2 studio already ..But i do not know which sub-vi must i use to either read the sensor or represent the sensor in labview.Must i use " Find Home" or "DAQ assistant" ??
(2,974 Views)
DAQ Assistant is for NI DAQ hardware. Your EPOS VIs are provided by Maxon, correct? If so, you need to ask them how they work.
(2,967 Views)
