Missing lvapp.lib
Hello 2 all !
I'm using LabView 8.5.1 on Windows XP SP2 and i'm trying to buid a executable based on a working vi.
But the build fails because, and i quote:
"Error copying files.
Source: D:\Program Files\National Instruments\LabVIEW 8.5\AppLibs\lvapp.lib
Destination: C:\Documents and Settings\Administrator\Local Settings\Temp\lvapp.lib.tmp"
" Error 7 occurred at AB_Engine_Get_AppShell.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
"Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer. "
How can i solve this ?
Thank you 4 your time.
Message 1 of 16
(6,067 Views)
I've searched tryed the following things :
1. Repair LabView - no luck.
2.Search my computer for lvapp.lib - no file found.
I've searche the forums, and came across http://zone.ni.com/devzone/cda/tut/p/id/6449#65891_by_Category.
This error should have been corrected in LAbView 8.5.1.
What else can i try  ?
Message 2 of 16
(6,065 Views)
HAve you checked/selected "enable debugging" while creating the exe?
Message 3 of 16
(6,064 Views)
No. I've tried to do the build with the default settings.
Message 4 of 16
(6,062 Views)
How can i enable debugging ?
Message 5 of 16
(6,060 Views)
You can do that while defining "build specification"
Message 6 of 16
(6,055 Views)
Message 7 of 16
(6,053 Views)
I've noticed the following thing...when i click the icon tab, the same error 7 appears...any ideas ?
Message 8 of 16
(6,047 Views)
I think that there must be something trivial like LabView doesn't know what icon to assign to the application.
Message 9 of 16
(6,042 Views)
I've tried to get an icon to the application. This doesn'e solve the problem. :((
Message 10 of 16
(6,038 Views)
