USB 6008 trigger
Hi James,
Thank you for VI. I would like to try it. But I do not open it. can you send me before version?
Message 11 of 19
(3,212 Views)
Hi 1085,
when you want a "previous version" of a VI you should tell which LabVIEW version you use.
And sometimes its faster to recreate a VI from scratch. (And you could learn to use LabVIEW that way much faster.)
Message 12 of 19
(3,208 Views)
Agreed. The VI I made above was purposefully roundabout. It is very simple to write that code from looking at the snippet, but also very simple to write your own with the tiniest bit of research.
Cheers
Message 13 of 19
(3,197 Views)
Hi James,
Thanks again for the VI. I tried it. But analog input signal is not triggered. What is the reason?
Thank you for your help.
Message 14 of 19
(3,138 Views)
Hi number,
Please send me VI, how is generated digital signal to send from 6008 digital output to PFI0?
You ask just that - and that's what the VI does: output a digital signal you can use to wire it to PFI0!
The VI does NOT trigger any analog input…
Open the example finder.
Search for an example that shows the usage of a "start trigger".
Open that example.
Run it. Test it. Understand it.
Come on, do some exercises!
Message 15 of 19
(3,131 Views)
The VI triggers a digital output, not an analog input.
If you want to read an analog input, then create a DAQmx task for your analog input. This analog input can be triggered by PFI0, but you're using a waveform graph in LabVIEW to do the triggering, so it would make no sense to use PFI0.
Just read from your analog input at a certain frequency for a certain number of samples and you only ever need to configure one channel.
Edit: Smiley LOL
@GerdW wrote:
Hi number,
Cheers
Message 16 of 19
(3,126 Views)
I agree with James. Generating a digital signal in LabVIEW to trigger an analog acquisition is just a Rube Goldberg.
Message 17 of 19
(3,108 Views)
Thank you for your reply.
Have a nice day:)
Message 18 of 19
(3,086 Views)
Have a nice day:)
Thanks are best given in the form of Kudos and Marked Solutions (Unofficial Forum Rules and Guidelines). You received assistance from some top-tier LabVIEW experts here, whom I'm sure would appreciate your gratitude. Marked Solutions help others find this post when they have the same issue and Kudos motivate us all to keep coming back to help! Smiley Wink
Cheers
Message 19 of 19
(3,058 Views)
