USB-6009 is not being recognized in MAX
I am doing a lab at school and I downloaded Labview and NI-DAQmx Device Driver for my computer. Plugged in the NI USB 6009 windows 7 begain the new hardware screen, found the driver and said it was working correctly. I go into MAX and there is not a USB DAQ listed under the devices and interfaces. Any ideas
Message 1 of 24
(7,288 Views)
Check as well under "Data Neighborhood" and what you have. Try to post a picture what you have there.
Message 2 of 24
(7,284 Views)
Here is the screen shot of MAX
thanks Again
Message 3 of 24
(7,280 Views)
Accepted by Mkirkness
Here are a couple things to try:
A) Refresh MAX: Either View>>Refresh or the F5 key
B) Device loader service is not started: In Windows go to Start>>Control Panel>>Administrative Tools>>Services. Scroll down to "NI Device Loader" and make sure the service is started. You may need to close and re-open MAX to see your device.
If those don't fix it, post back on this thread and we can work out a more specific solution.
Tim W.
Applications Engineering
http://www.ni.com/support
Message 4 of 24
(7,247 Views)
Hi, i'm also have the same problem, but i'm use USB 6008, the device is not display in device and interface in MAX, i have tried to do as solution but the condition still the same, help me with this. for your info, i'm using window 7
Message 5 of 24
(7,121 Views)
Hi mohd,
What version of the DAQmx driver are you using? Is your device recognized by Windows? To check this go to Control Panel>>Device Manager.
Tim W.
Message 6 of 24
(7,096 Views)
i'm using daqmx 9.1.7 and the device install successfully.
Message 7 of 24
(7,084 Views)
What version of LabVIEW are you using? If you're working with LabVIEW 8.6 or higher I would suggest upgrading your DAQmx driver to version 9.4.0. You can find it at this link.
Tim W.
Message 8 of 24
(7,071 Views)
Another question: are you using Windows 7 or XP? If you're on XP, there is a hotfix from Microsoft that is available here.
Tim W.
Message 9 of 24
(7,050 Views)
I'm having problems detecting my USB-6009 at all.  When I plug it in an error comes up that says "Windows could not load the installer for DAQDevice." and then goes to a new hardware wizard that is unable to find the drivers also.  I am running Windows XP 64-bit and have DAQmx 9.4 installed.  I checked in MAX and "NI-DAQmx Device Driver 9.4" appears under software.  I did not install the hotfix that Tim mentioned because my computer is not crashing and I am not getting the errors mentioned on microsoft's site.  Not sure where to go from here...
Thanks for any help!
Message 10 of 24
(6,991 Views)
