USB-6009 pulse train generation with digital output....
Hello!
I've bought a new USB NI-Card (USB-6009) and now I'm trying to adopt an old vi that uses traditional DAQ drivers. I wrote that vi for a PCI NI-Card (PCI-6024E), which has two counters to generate two pulse trains simultaneously. Now I've only one counter and that's why I'm searching for a good way to create pulse trains using a digital output! The pulse trains are both ranging between 100 Hz and 100 kHz.
I'm sure somebody has an idea how I can solve the probem in the best way 😉
Kind regards,
Peter
(4,041 Views)
Sorry, I forgot to mention that it hasn't to be a digital line. An analoge line is also okay!
(4,035 Views)
You can't do it with this low cost board. Both digital and analog outputs are software timed only. The analog out is rated at only 150  samples/sec and the digital is about the same. You can't even use one of the counters because it is not a hardware timed counter output. It is an event counter only as an input.
(4,033 Views)
Hello Dennis!
Thank you very much for your quick response. I'm sorry that it's not possible 😕
Kind regards
Peter
(4,016 Views)
