USB-6215 with Dynamic Tasks and LabView Mobile
Information in Dev. Zone appears to be contradicting, regarding this.
Is it possible to use USB-6215 with WinMobile 5 or 6 and LabView Mobile with Dynamic Tasks??
The following NI page "Performing Handheld Measurements using LabVIEW Mobile and NI USB Data Acquisition Devices" http://zone.ni.com/devzone/cda/tut/p/id/7705
suggests that this is supported.  Table of supported devices includes the USB-6215, but saying it is supported only with dynamic tasks.
But this other page "Differences Between Static and Dynamic Tasks in NI-DAQmx Base"
http://digital.ni.com/public.nsf/allkb/455824867BE50ED68625747F005A8B17
suggests otherwise, saying "Other devices (including M Series PCI/PXI, USB-621x, etc) are NOT supported by the NI-DAQmx Base Task Configuration Utility or NI-DAQmx Base static tasks."
These refs are both to DAQmx Base 3.2.
My intent is to use DaqmxBase 3.2 & USB-2.0, but am interested if USB-1.1 works as well.
Al
(3,328 Views)
Clarification:  I just noticed that the last quote says "NI-DAQmx Base Task Configuration Utility" which is consistent with not supporting Static Tasks.
But it still doesn't list whether Dynamic tasks are suppported for USB-6215.
Al
(3,326 Views)
The original KB you linked to does specify that the USB-6215 supports dynamic tasks.
Jeremy_B
(3,278 Views)
