adding more text to a file path
I am looking to write to a .xls file and have the user choose the directory they wish to write it to.  So far I have used the file I/O functions to check if the folder exists and if not create the folder.  The problem I have is that the "write to spreadsheet file" requires both the directory and filename to be included and I just have a folder name. I have attached a simple example of what I'm trying to do. Could someone please tell me how to add the filename to the folder directory, i.e. have my VI output c:\test\file.xls  instead of just c:\test
(2,974 Views)
In the file io palettes use the build path vi.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,968 Views)
thanks paul!!
(2,959 Views)
