USB 6343 daqmx multiple digital waveform outputs with different settings
Hello everybody,
I have 2 brief questions:
-I am trying to achieve multiple waveform digital outputs (works), but I would like to give an offset for some channels (so they are timed a bit later than others) and possibly
different frequencies. Is this possible? I have the USB 6343
-Is there a way to start multiple tasks? Bascially I want the DO's to be continuous cycling and get some analog input data only occasionally.
Thanks!
(2,660 Views)
Thanks for your posting in this forum. For your first question I attached some example which is maybe useful for you.
About  your second question I have to say that it is not possible. You cannot use USB X Series devices in multi-device tasks.
If you have any other question don't hesitate to ask.
Hosserin
(2,638 Views)
