USB-6343 not configurable with instrument I/O assistant
Hello everybody,
This is the first time I am using a NI device with Labview (normally using third party equipment), and I have trouble settings it up.
The device driver istalls fine and I can see it with the measurement automation & explorer. What do I need to set up there to be able to make labview nodes?
I always get the message that I need to configure it first (list remains empty). What do I need to configure? I tried adding a task but I cant see anything else.
(2,576 Views)
Accepted by topic author _Faust
You are using the wrong wizard. Use the DAQ Assistant.
(2,568 Views)
