convert 1D array to 2D array
Hello everyone,
In this topic http://forums.ni.com/t5/LabVIEW/Find-position/td-p/2059690 I have create a 1D array of string.
But no I would like convert this 1D array of string to 2D array of string.
I have try a for loop with inside a Build Array but in output it's a 1D ...
Do you have any idea?
Message 1 of 12
(12,304 Views)
I have try too a same idea of "read from spreadheet file.vi" because for my 2D array I would like \t for delimiter.
Message 2 of 12
(12,302 Views)
@kourte wrote:
Hello everyone,
Already answered in your original post.
For others: Build Array.
I have no idea what you are saying here. Is this a question, or a follow-up comment?
Message 3 of 12
(12,292 Views)
You can use Build Array (array pallete) to convert the 1D array to 2-D. You'll have to remember to wire an array constant (string in this case) to the second input of the Build Array VI.
-CC
[Edit: sorry for the repeated info here - didn't see Smercurio's post until after I'd written mine]
"If anyone needs me, I'll be in the Angry Dome!"
Message 4 of 12
(12,290 Views)
No you don't.  You can resize the node to 1 input.
Message 5 of 12
(12,281 Views)
Every day is a school day!
-CC
Message 6 of 12
(12,276 Views)
Hye everybody,
thanks for your answers but I would like a tab for delimiter with the 2D array.
Message 7 of 12
(12,269 Views)
Just to clearify with an example:
You currently have:
    "a\tb\tc","d\te\tf"
and you want to convert to:
   "a","b","c"
   "d","e","f"
Message 8 of 12
(12,266 Views)
Hye,
yes.
I have for example this
06/11/2012\tCheckout\t...
and I would like the 2D array as in the  picture
Message 9 of 12
(12,253 Views)
Hi kourte,
use SpreadsheetStringToArray to convert a single string. Use a FOR loop to convert an 1D array of strings, which will yield in a 2D array...
Message 10 of 12
(12,248 Views)
