USB 6501
I have downloaded the example USB-6501 Interactive Control but I can’t use it. I plug in my computer with the adaptor box and I check the 25 pins of the tester. With a multimeter I can calibrate all the pins and I observe that some of them have 5volts and the others have 0, high and low level, as it is supposed to be.
However, when I run the program and I try to change from High to Low it appears this error:
Error -200220 occurred at an unidentified location
Possible reason(s):
Device identifier is invalid.
If I change the name I have a different error:
Error -200558 occurred at an unidentified location
Possible reason(s):
One task cannot contain multiple independent devices.
Create one task for each independent device.
I don’t know if I’m introducing bad the name or what can be wrong. I would thank if someone could help me.
Vicente
(3,058 Views)
Hi Vicen,
If you check in NI-MAX (Measurement and Automation eXplorer), does the NI USB-6501 device show up in the Configuration tab? (My System > Devices and Interfaces > NI-DAQmx Devices). If it does, is it the same name you are putting into the "Device Name" of the Interactive Control.vi?
Also, have you installed the drivers for it?
(3,030 Views)
