SEND A WAVEFORM GRAPH TO A SPREAD SHEET
hi,
I ahve and application that reads data from a load cell and generate a graph (a waveform graph is used) and save some test data to a excell file.
there's a way to save also the graph to the same excell file where the test data is saved??
MG
(2,392 Views)
Try out with the Write to Spreadsheet File.vi.
Or, are you using the Excel toolkit ?
- Partha ( CLD until Oct 2027 🙂 )
(2,382 Views)
