Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
SEND A WAVEFORM GRAPH TO A SPREAD SHEET
DUKMARIVAN
Member
09-04-2007
08:30 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
hi,
I ahve and application that reads data from a load cell and generate a graph (a waveform graph is used) and save some test data to a excell file.
there's a way to save also the graph to the same excell file where the test data is saved??
MG
0
Kudos
Message
1
of 2
(2,399 Views)
Reply
Re: SEND A WAVEFORM GRAPH TO A SPREAD SHEET
parthabe
Trusted Enthusiast
09-05-2007
01:44 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Try out with the Write to Spreadsheet File.vi.
Or, are you using the Excel toolkit ?
- Partha ( CLD until Oct 2027
1
Kudo
Message
2
of 2
(2,389 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
