dphan128 wrote:
> Hi All,
> I'm new to programming LabVIEW to accept barcode scanner input. But from reading all postings related to barcode scanner, I noticed that USB type barcode is easier to implement since it is plug and play (no driver required) and it is acting as keyboard type of input. Please confirm.
> Thanks
> Dan
Dan,
You are correct, the USB barcode scanner would be the easiest to
implement. It would also be very cheap (check ebay for USB barcode
scanners). The USB scanner acts as a 'keyboard' type element, in that
if you scanned a barcode it would have the same effect as typing out
the barcode numbers individually on the keypad. Hope this helps...
-Ray
