USB Communication UsbLibrary
I have an application which needs to monitor some button presses of USB devices. People suggested me to use this UsbLibrary.dll to do it. The .NET Constructor Node did recognize this library, but I don't know how I can move forward. My goal is that after I input the manufacturer ID and device ID, then the program will show me the command sent through this specific USB port.
I will also attach this library and hope someone can give some clue.
Thank you in advanc.
(4,735 Views)
I'm not sure how we can help you. The library you have is a .NET library, so if you need help on how to use it then you should ask the folks who actually wrote it. The zip file you provided does have an example program so you could follow that to see how to use the library.
(4,717 Views)
Thank you for the response.
I know this subject is beyond LabVIEW scope. I'm trying to figure out how to make it work, but I'm lacking the related knowledge. I just hope some people with the knowledge of the specific library can provide some help. I think this is a good application and many people can use it.
(4,713 Views)
