USB block diagram
I am currently using labview 2010...I woud like to know how to create a block diagram for detecting USB port
Please advice
Message 1 of 43
(5,753 Views)
Message 2 of 43
(5,728 Views)
Hi Mike,
Do you have a simple block diagram that detect USB com port(e.g.com1,com2,etc)?
Please advice
Message 3 of 43
(5,722 Views)
do you mean USB or COM Port? Can you please explain a bit more?
Mike
Message 4 of 43
(5,716 Views)
Hi Mike,
I am currently doing a project for communicatio through USB...I want a simple block program that can detect a USB port so that I can excute the rest of the program.
Please Advice
Message 5 of 43
(5,710 Views)
Hi undergraduate,
the first post shows how you can get the event if a new USB device was attached. If you need the available COM Ports, then you can use the "VISA Find Resource" function.
Mike
Message 6 of 43
(5,708 Views)
Hi Mike,
Can you help me to write a example program on how to use the visa find resource function?
Please Advice
Message 7 of 43
(5,702 Views)
Hi undergrate,
where do you have problems with it? If you use it, you'll get a list of found devices.
Mike
Message 8 of 43
(5,699 Views)
HI Mike,
I am not sure which nodes should I use for this function will automatic detect and list the devices found?
Please Advice
Message 9 of 43
(5,683 Views)
Hi undergraduate,
what is your problem with this function? Is the help not self-explaining?
Message 10 of 43
(5,674 Views)
