USb-6221 Clock
Hi I'm using a USB-6221 to generate a 25Hz 50% Duty Cycle signal using Ctr0 from which I need to count the pluses.
I tried using the Connect Terminals.VI to connect the output of the ctr0 (PFI12) to the gate of the Ctr1 Gate and then count the plused using the CI Count Edges DAQmx vi this generates the error,  Specified route cannot be satisfied, because it requires resources that are currently in use by another route. I would appreciate any help!
Message 1 of 1
(2,373 Views)
