Ultrasonic Example Code Help
Attached is a sample VI for Ultrasonics. Could you explain the program in the block diagram starting from the left side to the right side of the while loop?
Could you specify what each subVI does and what do the numbers mean? Thank you
(3,031 Views)
Hi Questioner,
Open the context help: now you can read a short description for each function in the block diagram. You even get a link to a more detailed help article.
About that number: did you read that big comment in the block diagram???
Did you notice those "Training resources" offered in the header of the LabVIEW board? Did you take that training?
(2,982 Views)
Hi GerdW,
@GerdW wrote:
Hi Questioner,
Thank you for the reply. The context help is very helpful.
I was not able to find the "Training Resources."
Is that located in the main menu of LabView or on this website?
Could you provide a link to that please (if possible)?
(2,941 Views)
You found the LabVIEW Community Website (it's where you posted this question).  Look on the first page, where it says "LabVIEW Training Resources".
LabVIEW Training ResourcesLabVIEW Training Resources
You can also go to the Web and search for "Learn LabVIEW" or "LabVIEW Videos", or find a resourceful undergraduate Engineering Student who is willing to answer your questions.
(2,932 Views)
