Unable To Locate Exercises Folder
Hi all,
I've gotten LabVIEW 2014 recently and I want to learn the basics. Having the introduction course manual I in hand, the exercises required the vi files from a folder (C:\Exercises\LabVIEW Basics I\) however, I am unable to locate the exercises folder in my computer. I've tried searching every possible locations and I suspect I might not even have the folder afterall. Can anybody tell me where to get the exercises?
Thank you in advance!
(5,048 Views)
I am not sure about the Excercises folder, but you have plenty of examples on the LabVIEW fundamentals which will give you a good idea about the LabVIEW components. You can go to Help>Find Examples to browse the examples.
(5,040 Views)
Accepted by jamieyeap91
Up through LabVIEW 2011, the Academic kits included LabVIEW Basics 1 and 2, along with the Exercise folders (which were installed when you installed the software on your computer).  NI no longer distributes this with the Academic kits.  Users under support (I believe) can access (some of) this course material on the NI Web Site, but there is additional introductory material and tutorials available.  I've borrowed these links from Hooovahh -- (Tutorial links are at the end ...)
(5,007 Views)
Do you have a hard copy of that course manual?  If so, it should have come with a DVD if I remember correctly.  Did you install that?
(4,996 Views)
when you have NI core 1 course and you download the resources file and exercise file, check in your download section it will be there the reason u were not finding it may be that it was not extracted , extract it and than use it ...good luck
(2,414 Views)
