 jwright30
			jwright30
			10-11-2023 02:38 PM
I am using a sbrio-9609 with two usb-c ports. One is the host port and the other is the device port. I am unable to see a usb-a flash drive when connected to the device port. I can see it on the host port, but I am using the host port for embedded UI. Is there a reason for this?
-Jonathan
Solved! Go to Solution.
 ZYOng
			ZYOng
			10-11-2023 03:00 PM
It is expected. What exactly are the differences between a USB host and device
The host initiates all communication on the bus, the device only responds when asked by the host. For Details see the specs on usb.org.
A device port cannot be used to communicate with any devices. It is meant to be used for a host PC to communicate with it for NI MAX detection or code deployment. Most PCs only have host ports.
10-11-2023 03:09 PM
Thanks for the info, I was unaware of this.
