Unable to See USB flash drive on sbrio device port
I am using a sbrio-9609 with two usb-c ports. One is the host port and the other is the device port. I am unable to see a usb-a flash drive when connected to the device port. I can see it on the host port, but I am using the host port for embedded UI. Is there a reason for this?
-Jonathan
(1,206 Views)
Accepted by topic author jwright30
It is expected. What exactly are the differences between a USB host and device
The host initiates all communication on the bus, the device only responds when asked by the host. For Details see the specs on usb.org.
A device port cannot be used to communicate with any devices. It is meant to be used for a host PC to communicate with it for NI MAX detection or code deployment. Most PCs only have host ports.
https://tmesystems.net/
(1,196 Views)
Thanks for the info, I was unaware of this.
(1,184 Views)
