Unable to copy graph images from Labview
In Labview 7.1, I could select a 3D plot and paste the image directly into a Powerpoint or image document.  In Labview 8.0, it shows up as a blank box saying "Control could not be Loaded".  Is there another way to select graphics from Labview 8.0? or do i have to go through the trouble of a print screen and cropping.
-Matt
Message 1 of 9
(3,627 Views)
try using the Invoke Node -> Get Image.  I'm not sure how well it works though.
See-Ming
Message 2 of 9
(3,576 Views)
Do you want to do this programatically, or do you simply just want to right click on the graph, goto data opperations and then select copy data.  Now wou can paste it into office.  What you were doing was trying to copy and paste the entire activeX control through object embedding.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 9
(3,570 Views)
I do not want to do it programatically, the method you described didn't work.  When I tried to paste into a powerpoint, I got the same grey box as before.
-Matt
Message 4 of 9
(3,557 Views)
If you just need the image, can you do a Print Screen?
See-Ming
Message 5 of 9
(3,546 Views)
Sorry, this is the method I use but I havnot migrated to 8.0 yet, it does work in 7.0 I just tried it.
Paul Falkenstein
Message 6 of 9
(3,540 Views)
Hello Matt,
It works just fine for me with LabVIEW 8 and PowerPoint.  Try pasting it into a blank image in MS Paint to see if that works, it might be a setting in Office somewhere....
Travis M
LabVIEW R&D
Message 7 of 9
(3,532 Views)
Intensity and waveform graphs work fine.  It's the 3D Surface Graph that won't work in Labview 8.  I tried it on another computer so I don't think it's just me.  Any other ideas?
-Matt
Message 8 of 9
(3,521 Views)
Hello Matt,
I have bad news and good news.  The good news is that you aren’t doing anything wrong which leads us to the bad news – this has been reported as known issue in LabVIEW for 8.0 (CAR  ID 3U6HCSRL).  This is something we will investigate but we have no updates on it yet.  For now it looks like our good friend <ctrl><alt><printscreen> with some photoediting will be the way to go.
I do apologize for any inconvenience this will cause!
Travis M
LabVIEW R&D
Message 9 of 9
(3,511 Views)
