Unable to create registry key with Admin rights
Hi All,
I have created a simple program with the intention of counting the number of times the program itself runs.  This is done by creating a registry key and incrementing a value each time 'OK' or 'STOP' is pressed.  When the total number of button presses exceeds a value (5 at present) a message is flashed on screen and the registry value is reset.  I can only get this to work if I create the registry key manually.  This is a bit of a pain, and not everyone is comfortable editing the registry in this way in case they make a mistake.  I thought Labview could create registry keys automatically, as long as the user has admin rights - is this possible?
Ideally I would like to create an installer to create the registry key, but I don't believe this is possible with Labview v7.1.  Creating C code is unfortunately beyond my abilities.
Any help muchly appreciated!Smiley Happy
Dan
(4,720 Views)
Hi Dan,
LV can create registry keys, also without admin rights - atleast in the CurrentUser-tree...
I never had problems (using Create Registry Key, Write Key, Close Key) with LV7.1 and LV8.5, Win2k and WinXP.
(4,715 Views)
Hi Dan,
i think the problem in your vi is, that you connect the error line with activ error in it, to the create registry vi. I think you should first check whether the value exist and if not create it with connect error constant without activ error.
Mike
Message Edited by MikeS81 on 01-29-2008 07:03 AM
(4,707 Views)
Hi Dan,
i create an example for you. Pleae see the attached vi or picture.
Mike
(4,699 Views)
Thanks Mike.
I can't open the vi as it was created with v8.5.  I don't suppose you could save it as v7.1?
Otherwise I will try to decipher the picture - I haven't looked at it for long yet.
Thanks again for your help.
Dan
(4,694 Views)
Mike,
I have got it to work now using your diagram - Thanks!
Dan
(4,679 Views)
