resetting indicators
Hi
I have a sequence structure within a loop. I wish to illuminate a series of boolean indicators to show progression through the sequence. It would be nice if each went off when the locus of control moved out of the particular frame, but I would make do with starting each iteration of the loop with them all off. There's probably an easy answer but I just can't see it.
Graham
(3,280 Views)
Hi Graham,
you can use a property node to change the value. Or you create a reference of your indicator, necessary if you will set the value in an other vi.
Mike
(3,275 Views)
I you have the flexibility, you could use a case statement instead of a sequence structure to create a simply state machine.  You could use the index to move you through each state and use a boolean array to indicate the status.  The index of the loop would index which boolean in the array is active.
The attached screenshot should give you an idea.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,259 Views)
Hi
Thank you Both for the guidance; two different slants on the problem. The property node (which I haven't used before) answer fits the bill exactly.
regards
Graham
(3,226 Views)
