Unable to find HDL Interface Node
I have MyRio and LabView 2014 with all the modules installed and updated.
Xilinx 2014 is also installed and I can compile for FPGA.
However in block diagram I can't find HDL interface Node for importing VHDL code. As you see in the second screenshot.
How may I solve this issue?
Message 1 of 8
(6,002 Views)
Try searching for it by clicking on the search button on the functions pallete or by pressing control+spacebar.  You can also change your visible palletes to all and browse that way.  Good luck.
Message 2 of 8
(5,969 Views)
You mean that IP Integration node?
Message 3 of 8
(5,966 Views)
I can find IP integration node. However I'm looking for HDL Interface Node as it is mentioned in the following whitepaper:
http://www.ni.com/white-paper/3483/en/
I think the functionalities are the same. Maybe NI has replaced the HDL interface Node with IP Integration Node?
Message 4 of 8
(5,940 Views)
me too  need the answer....
Message 5 of 8
(5,700 Views)
Did you find HDL interface node?
Message 6 of 8
(5,666 Views)
Accepted by aan928
The is no IP integration node in LabView 2014. Instead use HDL Interface Node.
Yes I did use HDL Interface Node and it worked great.
Message 7 of 8
(5,654 Views)
I know this thread is really old but just to help clear things up from aan928's confusing solution for anyone else who comes across this forum post:
The HDL Interface Node was replaced with the IP Integration Node beginning with the LabVIEW 2010 FPGA Module.
Message 8 of 8
(4,817 Views)
