Unable to install labview 2012
I  am trying to install labview 2012 on my Windows 7 64 bit system,but it fails;
Here is symptom:
1) I click the setup.exe directly and it shows that:
2) if I run it with administrator, it shows that:
3) i have checked that I can run other exe file...
(2,880 Views)
Accepted by topic author bestchun1
Hi Bestchun,
It could be a corrupted installer file. Please try re-downloading the installer from ni.com/downloads.
I'll monitor this post, so reply if this doesn't work for you.
-N
Staff Certification Engineer
(2,844 Views)
Hi, Thanks. It was caused by the windows 7 extracting tool. When I use WinRAR, it works.
Thank
(2,822 Views)
