Unable to save different string value in each element of array
I have a VI setup to read multiple channels from a Veristand Project.  The input is a 1D array of strings, (one element for each channel I want to read).  The channels have different names, so each of the string elements needs to be different.  I am able to edit each element and run the VI, and it works fine.  However, if I save, close and reopen the VI, all of the elements show the same value (which happens to be the value of the last element for which I defined a default value).  Is this behavior expected, or have I missed a configuration setting that would allow different string values?  Please advise.  Thanks.
GSinMN
(2,673 Views)
Accepted by GSinMN
Make sure you're selecting the Array and not just an element when you do the Right Click-> Set Value to Default on the Front Panel control.
(2,672 Views)
Never thought of that.  Would have thought you needed to select each element.  Looks like the answer.  Thanks.
GSinMN
(2,666 Views)
