Unable to see Contents in Block Diagram(Labview Version 13.0)
Thank you so much  Trusted Enthusiast for the help 🙏 . I solved my issue.
but tell me how you solved this issue.? how you got back the whole block diagram?
Message 21 of 22
(604 Views)
This particular VI was pretty straightforward to fix, all it took was a little scripting.  Listing the BD objects revealed two, the tab control terminal and a while loop.  Checking the bounds of the While Loop showed the problem.  So I simply used a bit more scripting to set the Content Rect of the While loop to a finite value, and then let Auto Grow snap it to its still-huge proper value.  I would post the VI, but it was disposable and I did not even bother to save it after it did its job.
Message 22 of 22
(572 Views)
