Unable to see Shared Network Variable on Client PC
I have 2 LabVIEW applications, one is an executable and one is currently in development and doesn't have an executable yet, so i am running it from the programming environment. The executable LabVIEW application contains a Shared Network Variable library which is deployed when the application loads up. These applications will be running on two separate PCs via Ethernet.
I am wanting to read the Shared Network Variable that is deployed over the network but i am having issues whereby when LabVIEW deploys the variable over the network successfully on the Server PC and i can see the variable running ok in the NI Distribution Manager, but the other PC (i.e. the client), i can't see the variable - so i went into NI Distribution Manager and could not see it listed even though the two PCs are connecting and communicating and both NI Variable Engines are running fine.
I have tried all the troubleshooting methods that NI have written here -
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6vdSAC&l=en-GB
…I have tried restarting the services, stopping processes etc... but not luck 😞
Note: when i run both applications on the same PC, the network variable is visible and i have no issues with reading it, but when it comes to working on 2 separate PCs, it doesn't work which is frustrating... could this be related to Windows security? When i run on the same PC, i am using Windows 10. When i run on two separate PCs; the client is on Windows 10 and the server is on Windows 7.
Server application was built in LabVIEW 2011 and the client application is running in LabVIEW 2019.
(2,364 Views)
Accepted by topic author MarcusT_NI
Update: Issue resolved.
The problem was the network was set to Public which stops Network Shared Variables from being accessible over the network to other PCs. I changed the network to Workplace and it works now.
(2,295 Views)
