Unable to wire the terminals
Hello Sir,  I am facing problem with LabVIEW 6.1 version, which I have on my board.  I am not able to wire the terminals when i wish to connect two VI's. When I place my VI on the diagram panel, its not showing me the terminals thorugh which I can connect two VI's. What could be the possible reason for this ? I would appreciate any kind of support!
Message 1 of 9
(5,897 Views)
Hi
I'm not really sure what you mean, but usually, the terminals appear, if you move over the vi with the wire-tool.
By the way - don't post pictures as *.bmp. They are to big - use a smaller type (*.jpg, *.png, ...).
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 9
(5,887 Views)
Hello Sir, thats the problem I am facing now. the terminals didnt show up when I place the cursor over the VI. I am looking for the possible reason for that. It should be that way. I dont know whats wrong with that!
Message 3 of 9
(5,878 Views)
Do you have this problem just with the vis in your picture or also with others?
Using LV8.0
Message 4 of 9
(5,872 Views)
Hello Sir,  I have problem with all the VI's that I am using. I am using LabVIEW 6.1 with Windows NT.
Message 5 of 9
(5,867 Views)
So I think the best way to solve this problem is to repair the LV-Installation or install it new.
Using LV8.0
Message 6 of 9
(5,863 Views)
Hello Sir, Thanks a lot for the support. I have a plan to uninstall and upgrate it to a newer version than what I have. It should work because I worked on LabVIEW 7.1 already and I felt confortable working on that specific platform! Thank you!
Message Edited by Kay Kay on 09-21-2005 12:20 AM
Message 7 of 9
(5,860 Views)
place the cursor over the VI and press TAB.
e.
Message 8 of 9
(5,843 Views)
Maybe you were using before labview 7.  You have to go to windows>tools palete, and you will find there an option to change to the wire tool.  A faster way is to push the space bar... you will switch between wire and normal cursor
regards
Carlos Arcediano del Amo
Message 9 of 9
(5,837 Views)
