Unbundle a 2D array of clusters from a database
Hello, I have used the DB Tools Fetch Rercordset Data.vi to take data from a database. The data is a (2D array of Clusters). I want to separate them to know the data type of every column in my database. Any help?
(1,729 Views)
Accepted by electronic_lab
If you want to inspect your database structure, there are useful VIs in sub-palette "Connectivity->Database->Utility" which allows to list tables in a database, columns in a table, get properties, ...
"DB Tools List Columns.vi" gives you the columns' types of a table. The types all have equivalents in LabVIEW:
As far as I know:
String -> LabVIEW String
Long (I32) -> LabVIEW I32
Single (SGL) -> LabVIEW SGL
Double (DBL) -> LabVIEW DBL
Date/Time -> LabVIEW Time Stamp
Binary -> LabVIEW String
Then with your "recordset data", you can use "Database Variant To Data" and wire the type to convert it to usable LabVIEW types.
Raphaël.
(1,683 Views)
Functions -> Programming -> Cluster, Class, & Variant -> Variant -> Data Type Parsing -> Get Type Information.vi
(1,680 Views)
Why would you need to "separate them" (I don't even know what that means!) to know the datatypes? In LabVIEW, a cluster is a structure defined at compile time and thus fixed. You can just hover over the terminal and see the types in the context help.
(1,678 Views)
