Unbundle an array of clusters
Im trying to figure out if it is possible to efficiently unbundle an array of clusters which contains about 20 elements without disassembling the array prior to unbundling the clusters.
Thank you,
Ran
Message 1 of 15
(11,458 Views)
What is it you want to do?  What is your goal?  I assume you want to do something other than put your array into a For loop, and within the loop unbundle the Cluster, then reassemble on the way out.
Bob Schor
Message 2 of 15
(11,423 Views)
You cannot "unbundle" an array of clusters, because it is an array, not a cluster. It would be interesting to know what you mean by "disassembling". Is the cluster of mixed datatype? What kind of data structure do you want at the end? (e.g. a cluster of 20 arrays? 20 individual arrays, one for each element? a N x 20 2D array? Just random access to a specific inner element? something else?)
I guess you figured out a way to do whatever you are trying to do, but you are worried about performance or efficiency. Is this correct? Do you have performance or memory problem? If so, what is the evidence? Can you show us your code? How big is the array of clusters?
Where does the data come from? If you feel that the data structure is not suitable for your use case, maybe you want to carry it as a different data structure from the beginning.
Message 3 of 15
(11,418 Views)
My guess is that you're looking for a function that is the complement of "Index & Bundle Cluster Array".
There's no built-in function for that, you just have to code it like this:
Message 4 of 15
(11,371 Views)
Accepted by topic author ran0
Exactly 😄
Message 5 of 15
(11,363 Views)
I asked this same question about a week or so ago.  Unfortunately, the answer is the same.  😉
Bill
CLD
(Mid-Level minion.)
Message 6 of 15
(11,338 Views)
To make it clear
No
Message 7 of 15
(11,328 Views)
Thank you all...
My aim is to record about 20 mixed datatypes in one giant array. I thought it would be better if i cluster them all together, per iteration, and unbundle by request only the datatype array i want.
Since it can't be done, i guess i'll work with multiple arrays, as easy as it could be at first place.
Once again, I thank you all.
Ran
Message 8 of 15
(11,326 Views)
Here's a better solution.
Just drop "Index and Unbundle.xnode" onto the block diagram.
(To make it handy, add it to a palette.)
Message 9 of 15
(10,647 Views)
I just discovered that it gags when it comes across cluster elements with empty labels (but you're not supposed to do that anyway).
Here's the fix (it invents a name if it finds a blank one).
Message 10 of 15
(10,628 Views)
