Unbundle an array of clusters
I figured out a more efficient way to code some stuff.  Here is an improved version with better performance.
Message 11 of 15
(1,426 Views)
@ran0 wrote:
Thank you all...
My aim is to record about 20 mixed datatypes in one giant array. I thought it would be better if i cluster them all together, per iteration, and unbundle by request only the datatype array i want.
Since it can't be done, i guess i'll work with multiple arrays, as easy as it could be at first place.
Once again, I thank you all.
Ran
I'd go with the Cluster-Array. One Index Array and one Unbundle to get the data isn't much of a hassle compared to handling 20 arrays. If you think it's 'too big', make a VI of it. You could even be lazy and have 1 with all data types as different outputs (although it'll be a big ugly), you'll need the 6x4x4x6 layout for that.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 15
(1,408 Views)
Thank you! I don't know why this is not marked as solution.
Message 13 of 15
(1,309 Views)
I am getting an error saying Xnode is not executable. Do you know why?
Message 14 of 15
(1,308 Views)
What is the data type of what you are wiring to the function?  It doesn't look like a 1D array of a cluster it looks like it might be something else.  Post your VI or that data type and we can figure out why it doesn't work but like I said it is likely the wrong data type.
Message 15 of 15
(1,302 Views)
