Undefined Strings in Combo Box Bug?
I have found an issue with the Combo Box control:
1. Create a Combo Box and de-select "Allow Undefined Strings"
2. Run the VI
3. Select a Combo Box item
4. Press the backspace key to delete a few letters of the item
5. Click somewhere else on the front panel
The Combo Box will be populated with an undefined string!
Disabling the backspace key is not a valid work-around because the user may need this while typing the value.  Expected behavior for the control would be to revert to the previous value.  Any comments?
CLA, CTA
(3,599 Views)
Accepted by LVB
Yes.
Take a look at the bug report in this thread.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=379475
(3,597 Views)
Thanks, for some reason that did not come up in my search.
CLA, CTA
(3,594 Views)
