Understanding Hanning Window
I would like to understand how Hanning Window works. In the help section, the equation of Hanning Window is:
yi = 0.5xi[1 – cos ( ( 2 * PI * i  ) / n) ]
for i = 0, 1, 2, …, n – 1,
where n is the number of elements in X.
I created a array of four values: 150, 250, 250, 300. After Hanning Window I got the array: 0, 125, 250, 150
I am not able to realize how the equation was performed for each number because I don't understand where I will input the position of the value (first value of the series, second value of the series). The position its important because the same value 250 in the original array, resulted in different values in the array after Hanning, revealing that the position its important.
How would be the 4 equations to manipulate these four values in the original array?
Thanks for help
Dan07
Message 1 of 19
(11,059 Views)
Accepted by dan07
y0 = 0,5*150*(1- cos(2*PI*0/4)) = 0
y1 = 0,5*250*(1-cos(2*PI*1/4)) = 125
y2 = 0,5*250*(1- cos(2*PI*2/4)) = 250
y3 = 0,5*300*(1- cos(2*PI*3/4)) = 150
Does that help?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 19
(11,043 Views)
Hello Yamaeda...
Thanks for the answer, your equation its correct. I did not know about the 0/4, 1/4, 2/4....
But I still have a problem, when I tested your equatio in Microsoft Excel, I got the correct results, but when I tried to perform the calculation using a pocket calculator (HP 10s), the result for COS its different from that obatined in excel. For example, COS (1), its 0.540302306 in excel, and 0.999847695 in HP 10s. Do you know what is happening?
Daniel
Message Edited by dan07 on 11-26-2008 08:05 AM
Message 3 of 19
(11,021 Views)
Daniel,
One is in degrees and  the other in radians.
Lynn
Message 4 of 19
(11,016 Views)
John...
you are right.
Problem solved!
Thanks all!
Message 5 of 19
(11,008 Views)
can u give me information about 1/4th hanning window used to calculate weighted average.
Message 6 of 19
(10,894 Views)
Please can any one tell me about hanning window which is used for calculating weighted average.
Message 7 of 19
(10,835 Views)
Hello NBS
Sorry for the delayed answer. I don't know nothing about 1/4th hanning window used to calculate weighted average, but I will get some information about this and will send to you soon.
What kind of data you will apply the hanning window?
Dan07
Message 8 of 19
(10,807 Views)
I am doing project on DCT based iris recognition.
I am going to apply it to a normalised iris image of size 88 X 512.
Before applying DCT 1/4th hanning window is applied twice one in horizontal direction and other in vertical.
got information about hanning but not abt 1/4th.
Really confused abt its use.
Hope that u will find some way for me.
thanks alot.
Message 9 of 19
(10,790 Views)
Hello NBS,
I searched by informations to help you with your problem, but I got no success doing this.
I got tons of information about hanning window, but not for 1/4th.
Sorry and good luck
Dan07
Message 10 of 19
(10,700 Views)
