05-28-2018 05:52 PM - edited 05-28-2018 05:52 PM
I was referring to your FT library you are using. But from looking at the code you posted it seems the handle is on the LabVIEW diagram still an int32. When you read my earlier post it mentions having to do two things:
1) In the Call Library Node configuration change the datatype of any parameter which is of type HANDLE to be a "pointer-sized (unsigned) integer".
2) On the front panel of all driver VIs change the according numeric control/indicator to be of type "(unsigned) 64-bit integer".
05-30-2018 10:59 AM
It is solved
, it is working great, thanks a lot rolfk, I really appreciate your help.
05-31-2018 02:45 AM
@busha02 wrote:
It is solved
Then please mark a solution! It prevents others from opening this thread, trying to help. And others with the same problem will find the solution faster. You can mark multiple posts as solution, or make your own summary and mark that as solution, or both...
As a bonus your post will get a neat green tag, and you won't be spammed by the forum to mark a solution!
06-03-2019 05:53 AM
Dear @busha02,
I have problem with LabView 2018 64bit and FTDID2xx.dll under Windows 10 64bit.
Can you send me example code, working with this DLL properly.
leonid@duma.co.il
07-18-2019 02:39 PM
Recently working through issues with LV 2017 64 bit and FTDI myself. One thing I didn't see mentioned in this thread is that there is a 64 bit version of FTDI driver. If using LV 64 then use ftd2xx64.dll
07-18-2019 03:40 PM
This was actually mentioned in another thread that was recently getting active again. Also see there for a smart way to define the library name in the Call Library Node so it will work both for the 32-bit DLL and the 64-bit DLL.
03-25-2022 10:28 AM
Hello Mr. Kalbermatter,
Thank you for this message and especially for solving the problem. Before I read your answer, I was looking for caster handle in U64. I admit that for me it is not very clear when to use a pointer-sized (unsigned) integer or a U64.
With kind regards,
Joseph
