Unflatten variant from string got error 122
In this VI, when I used a 13 characters string to write flattened data to a file, I got error 122 when reading and unflattening it back. But with string that was not 13 characters, the unflattening operation worked just fine.
Any ideas ?
(4,636 Views)
Accepted by zigbee1
Make sure you turn OFF the "Convert EOL".  That could change your flattened data on you.  Alternatively, you could read and write using a binary file.
(4,544 Views)
 crossrulz is totally right about EOL interpretation when writing files. This has to do with 13 chars length string.
Thanks for helping me out ! 🙂
(4,509 Views)
