Unicode, LabVIEW and PDF Report
I am able to write Unicode (UT-16) characters in a PDF document (PDF report) with LabVIEW, but this is laborious. I try to find an easiest way.
I don’t want to enable the Unicode support with "UseUnicode=True" in the LabVIEW.ini (because too many weird things happen).
Here are the steps:
1) If I want to use Unicode, I write the text in Notepad, and I save with the encoding Unicode.
2) I have a VI who read this text file, remove the BOM (xFFFE) and write the rest of the content in a string.
3) I copy this string in a string of the PDF Report.
4) I do the conversion, of the string, to an array of U16.
5) I generate an Unicode string with the .net constructor “mscorlib(2.0.0.0).system.string”
6) I write this Unicode string in the PDF Report.
It works well (see the attachment), but the steps 1 to 3 are laborious.  I try to find another way, but I have no idea.
(4,370 Views)
Andrew,
Your links that begin with ae.natinst.com are not visible to anyone outside of NI.
(4,297 Views)
Sorry about that.  After taking a closer look, they cover parts of the same content as that first article.  It is a very good resource on the subject.
(4,282 Views)
Thanks for those links HandyAndy.
I already read the “A List of Tips and Tools for using Unicode in LabVIEW” a couple of times.  Like I said, I want to  simplify those steps (without activated the Unicode support with "UseUnicode=True" in the LabVIEW.ini):
1) I write the text in Notepad, and I save with the encoding Unicode.
Maybe it is impossible or maybe someone have an idea.
(4,279 Views)
