Unicode to UTF-8 conversion
Has anyone every done conversion of Unicode Characters (0000 - FFFF) to UTF-8? Are there any inbuild modules which can be used for this conversion?
http://www.utf8-chartable.de/unicode-utf8-table.pl?start=128&number=1024
There is a module ASCII text to UTF-8 which does not work for unicode characters.
-VS
(12,840 Views)
The safe answer is "Not Yet", based on a search of LabVIEW Help and a Web Search.  Part of the problem is that Unicode is U16, while ASCII (which LabVIEW basically uses) is U8.  You could write your own Translator/Mapper, but it would have to deal with the Many-to-One problem (i.e. you'd need to decide which 256 Unicode characters you wanted to display as which Ascii character).
Bob Schor
P.S. -- If I'm wrong about this, I have every confidence that other readers of this Forum will point out my error ...
(12,822 Views)
The conversion would be simple.  Why don't you write a VI for it and share it.
(12,813 Views)
Accepted by topic author V_T_S
Actually ASCII is a VERY LIMITED subset of Unicode. And no, Unicode ist not UTF-16, but UTF-16 LE (little endian) is de Unicode version used on Windows. You also have UTF-8 and UTF-32 and for the 16 and 32 bit versions both an LE and BE version.
Windows NT uses internally everywhere UTF-16 LE, while translating it to 8-bit MBCS on demand for applications that don't use Unicode such as LabVIEW. And LabVIEW therefore does not really use ASCII but 8-bit MBCS. For most Windows codepages this means an extended ASCII code page with the lower 128 character codes mapped to the standard 7-bit ASCII characters and the upper 128 character points mapped to code page specific characters. But Asian and Arabian codepages can define more than 256 characters and then a single character suddenly consists of multiple bytes even in LabVIEW.
Linux uses nowadays internally mostly UTF-32 (LE or BE) depending on the endianess of the CPU but with most user systems nowadays running on x86/64 or ARM this is usually also LE.
On the user level it uses UTF-8 which is in fact also a MBCS encoding where a single character point can consist of 1 to 4 bytes. The first 128 characters in the ASCII table map exactly to the first 128 characters in the Unicode standard.
So if your LabVIEW was running on on a modern Linux system you theoretically would already use UTF-8 Smiley Very Happy
On Windows to get to UTF-8 from UTF-16 LE one needs to simply call the function WideCharToMultyByte() with the first parameter set to CP_UTF8 (65001) instead of CP_ACP (0).
And be very careful to allocate a large enough buffer for the returned UTF-8 string. It can theoretically get up to 4 times as long in bytes as there are UTF-16 character points in the incoming string!
Rolf Kalbermatter  My Blog
(12,803 Views)
Thanks, RolfK, for the clear and concise response!
Bob Schor
(12,775 Views)
Thank you for the detail description RolfK!!
(12,769 Views)
