07-13-2006 03:38 PM
07-17-2006 09:54 AM
Hi pughjl,
Since the CWGraph3D control is an ActiveX object, you should be able to use it no matter what as long as it is properly registered and such. Were you able to successfully build your application in 7.1.1 before you installed LabVIEW 8 for evaluation? Also, does the error appear on your development machine or only on other machines? The problem could be that the ActiveX object isn't registered on your target machines. Please check out this discussion forum post which has some helpful links and information for building applications with the CWGraph3D.
Best Regards,
Megan B.
07-17-2006 02:19 PM
07-18-2006 03:17 PM
