‎01-04-2007 11:18 AM
‎01-05-2007
04:37 PM
- last edited on
‎04-11-2024
01:24 PM
by
Content Cleaner
Hi Siddhu,
The KnowledgeBase the discussion forum referenced is Executable Version (7.1.1) Doesn't Match Resource File (7.1). The next logical step to solve this problem is to uninstall LabVIEW 7.1.1 and reinstall. This will reinstall the Run-Time Engine and most likely fix the problem.
If you have the LabVIEW Standard Service Program (SSP), you can create a service request and call NI for one-on-one support with an Applications Engineer.
Michael K.
‎06-12-2009 03:06 PM
‎06-14-2009 06:15 PM
Hi Siddhu,
I am sorry for the limitation that you are running into here. As mentioned in the KnowledgeBase article that Michael referenced, this issue has been fixed in later versions of LabVIEW.
To work around the issue, you should be able to do one of the following:
1) Remove the LabVIEW Run-Time Engine 7.1.1 and install the LabVIEW Run-Time Engine 7.1 instead. This way, when you develop applications in LabVIEW 7.1 and include the Run-Time Engine with your executables you should not encounter the problem that you are seeing.
2) Do not choose to include the LabVIEW Run-Time Engine with your LabVIEW executables. Instead, separately install the LabVIEW Run-Time Engine 7.1 or 7.1.1 (both will support LabVIEW 7.1 applications) on your deployment machine(s). This should be the best method for avoiding the error that you are seeing, though it does mean that you will have to run two installers manually on your deployment machine(s).
Please let me know if you have any additional issues, and I am glad to help. I am sure that we can work together to get your application up and running.
Casey Weltzin | LabVIEW Real-Time Product Manager | National Instruments
