Unique regular expression to check if a string contains letters and numbers
Hi all,
How can I verify if a string contains numbers AND letters using a regular expression only?
I can do that with using 3 different expressions ([0-9],[a-z],[A-Z]) but is there a unique regular expression to do that?
Thanks all
Message 1 of 13
(16,572 Views)
@AC_85 wrote:
Hi all,
Thanks all
You can combine the classes into a single one [0-9a-zA-Z] or use the posix class [[:alnum:]].  To verify you simply match the negative class [^0-9a-zA-Z] or [^[:alnum:]], a non-empty match means that a non-alphanumeric was in the string.
Message 2 of 13
(16,563 Views)
two ways to skin that cat.
Message 3 of 13
(16,540 Views)
It looks like the previous answers will match a string that contains alpha or num, not alpha and num only.
Jim
Message 4 of 13
(16,527 Views)
Jim, Thanks for pointing out I missed the req.
I'd still go with the lex class over the regex just for readability (unless you are a regex guru)
"True if: A decimal digit Character exists And a alphabetic char exists And all chars are either Alpha or numeric"
Message 5 of 13
(16,516 Views)
I'm waiting for a guru to swing by and replace my regex with something much more concise.
Jim
Message 6 of 13
(16,509 Views)
Missed the requirements:
single regex:
^([[:alpha:]]+[[:digit:]]+|[[:digit:]]+[[:alpha:]])[[:alnum:]]*$
You either have 1 or more digits followed by 1 or more letters or 1 or more letters followed by 1 or more digits. Once that is out of the way, the rest of the string must be all alphanumerics.  The ^ and $ make sure the whole string is included in the match.
(I have not tested this at all, just typed it up hopefully I got all the brackets in the right place).
Message 7 of 13
(16,503 Views)
single regex:
I think you just made my point.  TWICE.Smiley Very Happy  While the lex class would be much more readable as a ring.... I know all my brackets are in the correct places and don't need to hope.
Message 8 of 13
(16,487 Views)
If you are keeping score:
1.  Bracket balancing is only a problem on my phone, in LV it is a easy to debug error.
2.  Using my regex helper means I do not even have to worry about it or remembering the exact syntax of any of the posix classes.
3.  I know precisely what happens with unicode fonts and languages with letters outside of A-Z (and I think I know precisely what does not happen with the lexical class function)
4.  Calculate how much time it takes to modify each version when you decide that radix points (. or ,) should be allowed, and then decide that negative numbers should be allowed.
Message 9 of 13
(16,480 Views)
I was not arguing the power of a regex.. I do use them often.  Not nearly as masterfully as I wish. but, that is what test cases and regex helpers are for!  In this case, a simpler to understand solution presented itself.  I like easy to understand code.  No love lost- the regex you showed probably would pass my helper.  (I did not test it either but, Darin can usually be trusted to type)
Message 10 of 13
(16,472 Views)
