Unique regular expression to check if a string contains letters and numbers
Darin.K wrote:
2.  Using my regex helper means I do not even have to worry about it or remembering the exact syntax of any of the posix classes.
What is your regex helper, please?
Message 11 of 13
(1,069 Views)
https://decibel.ni.com/content/docs/DOC-13698
Jim
Message 12 of 13
(1,059 Views)
@Darin.K wrote:
Missed the requirements:
single regex:
^([[:alpha:]]+[[:digit:]]+|[[:digit:]]+[[:alpha:]])[[:alnum:]]*$
You either have 1 or more digits followed by 1 or more letters or 1 or more letters followed by 1 or more digits. Once that is out of the way, the rest of the string must be all alphanumerics.  The ^ and $ make sure the whole string is included in the match.
(I have not tested this at all, just typed it up hopefully I got all the brackets in the right place).
When I copied your regex and pasted it into a string constant, I got ^([[:alpha:]]+[[:digit:]]+|[[:digit:]]+[[:alpha:]]​?)[[:alnum:]]*$, but the question mark disappears when I paste it into this response.  Weird.
Anyway, the question mark needs to be a "+" and it'll work.
Jim
Message 13 of 13
(1,055 Views)
